Maftpro v.5.27. O2 value is the same 4.40 to 4.60 engine is off or run. Afr gauge shows rich. I have looked at all the wires and connections look good but when I removed one wire (+5 v map) 6pin connector (maftpro) so everything looks good, O2 idle value is normal and Afr gauge also works as before, but when I put wire back so the value will rise again. There are Caspers harness(maft-ecm) and 85mm maf.
Lc-1 value was 21 or something, but did not have time to install Lc-1 back in place to see what is the +5 v wire removal effect.
All worked fine when I installed Maftpro.
What could be the reason for this? Something broken inside maft pro?
However, the car moves pretty well. It would be nice to have datalock the last race day.
thanks Ari
thanks Ari
