Hi all. I am working on a project with a mostly stock GN engine but being controlled with a Megasquirt ECU via MAP controlling the fuel injection and spark based on kPa and RPM.
I need to import the GN ECU spark advance table.
I have the GN ECU dump tables of spark based on LV8 and RPM. How do I use the LV8 numbers in my kPa and RPM spark table? I know LV8 and kPa are both load numbers, but there should be some relevant conversion between them. I've seen mentioned on other MAF -> MAP conversion systems to use LV8 255 as kPa 100, but that does not address boost loads.
Any ideas?
Thanks!
Any ideas?
Thanks!
