I'll start from the beginning. I installed an extender chip to match my basic translator after a turbo upgrade. For a few weeks everything was fine, blm very close to 128 while cruising and around 133 at idle. Now I've made a few changes and now idle blm is around 116 and sometimes a little lower. Seems to dance around quite a bit while driving from 116 - 133 or so (these numbers are after the changes made below).
Iac was about 40-50 at idle so I made iac and tps adjustments and now iac is about 20 but goes up to around 30 when the fans come on. Tps is .46 at idle in park, .42 key on engine off. How much will iac settings affect blm?
I had set fuel pressure to 45 psi line off per the chip instructions. After a few weeks I checked the fuel pressure and it was down to about 42 psi line off. I thought that was strange so I adjusted it back up to 45 and since then I've noticed it seems to be inconsistent with the line off. Possible bad fuel pressure regulator?
Thanks guys. I don't want to start chasing a ghost. I have an LS1 maf that's only about a year old. Translator settings are on on off off , both knobs set to zero.
