looking to go 18x8.5 in front with 245/40/18
and 18x10 with 275/40/18 out back
called the wheel place and they are a set wheel he said i should have no problem fitting wheel especially since i have gnx flares on my car.now i seen anthor member on here has same wheels but is running a 2inch spacer out back and 1/1/4 out front! my question is howsafe are wheelspacers if i do this do i need longer wheel studs? i just wanna be safe if i have to use spacers? any help would be great
rear specs
Specifications
Wheel Size
18x10
Color
Gloss Black
Bolt Pattern
5-114.3/5-120
Offset
+25
Backspacing
6.48
Lip Depth
3.5"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
23.3
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
front
Specifications
Wheel Size
18x8.5
Color
Gloss Black
Bolt Pattern
5-114.3/5-120
Offset
+25
Backspacing
5.73
Lip Depth
1.75"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
23.1
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
rear specs
Specifications
Wheel Size
18x10
Color
Gloss Black
Bolt Pattern
5-114.3/5-120
Offset
+25
Backspacing
6.48
Lip Depth
3.5"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
23.3
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
front
Specifications
Wheel Size
18x8.5
Color
Gloss Black
Bolt Pattern
5-114.3/5-120
Offset
+25
Backspacing
5.73
Lip Depth
1.75"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
23.1
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
