List of parts that can be found at Junk Yard.
Sal 87WE2
--NONE--
Should we make a list of cars and parts we should look while at the local Junk Yard?
For instance:
aluminum core support (hard to find). What year/make? I hear 79-80 Grand Prix are more common if found...
Aluminum Brake Drums, bumper supports/struts?
36mm LT1 Front sway Bar. F-bodys? what years?
Looking for mostly perf upgrades but any items i can include.
i know there are more out there and the list should not be that long, i can organize it, i just need the correct data.
Just something we can easily refer to and if we could make it a sticky? What do you all think?
Will The aluminum drums from an 87 IROC work? I used them for my '69 camaro years ago.
OK, so far i know...
Bumpers from 1981-1987 are the same. Chrome? Powder coat black if needed, place aound here charges shop minimum of $195
Headlight Bezels 1984? - 1987
Radiator supports start at what year? 1979? aluminum?
What about the braces found on other G-bodys?
Floor pans all G bodies 198? - 1987?
Vacuum brake pedal/booster 1984 - 1987 G Bodies
Header Panel 1984-1987
Hollow Sway Bars 32mm and 36mm - F Bodies 1992-2002?
I will add more and will update as i get confirmation...
Bumpers from 1981-1987 are the same. Chrome? Powder coat black if needed, place around here charges shop minimum of $195
Mini Starter: http://www.turbobuick.com/forums/junkyard-dogs/23707-lt1-starter-2.html
QUOTE=Justa6;
81-83 clear bumper lights- fit 84-87
81-87 Cutlass doors
Hollow 36mm F. sway bars 87 (I think) to prolly '92 3rd gen f-bodies
Aluminum bumper supports (front/rear) They should be model specific
All the support bracing from all g bodies (2 doors)
View topic - F41 and aftermarket bracing diagrams (MORE pics added) :: GBodyForum.com - '78-'88 GM G Body Community (good post)
brace (shows all the braces)
how about the blazer brake conversion i cant seem to find them was it 98 2wd 4 dr blazer..and the astrovan hydroboost units
Don't forget that the Blazer rear sway bar for the last model will fith the G body cars. It is better than the stock and is simular to the pro touring bar but not as thick.
Updated...
Aluminum Brake Drums: Long List, click here
Headlight Bezels 1984 - 1987
Aluminum Radiator Support: Look for Raised "A" on Radiator Support
78-80 Regal - Century
78-80 Cutlass
78-80 Grand Prix-Lemans
Click here for more info on core supports
Hollow Sway Bars 32mm and 36mm - 3rd Gen F-Bodies V8 Engines with 16" factory wheels. V6 models did not have them.
Click here for more info on sway bars
Mini Starter: Click here for more info on Mini Starter LT4
81-87 Cutlass doors
All the support bracing from all g bodies (2 doors)View topic - F41 and aftermarket bracing diagrams (MORE pics added) :: GBodyForum.com - '78-'88 GM G Body Community (good post)
Brace (shows all the braces)
Dual Electric Fan Setup: Click here for Info on Dual Fan Setup
"You want the dual fan setup from a '98 - '04 dodge intrepid. I believe all three engine options (2.7L, 3.2L, and 3.5L) had the dual fans. Actually any '98 and up Chrysler product will do - intrepid, concorde, LHS, 300M." - Anthony P
Radiator: OEM replacement Radiator from 1987 - 1992 Camaro
Thanks to Mark S for the updates.
Ok everyone, here is a great list compiled and submitted by Mark - O SO LO Thanks to him for getting all of this together and sharing.
Aluminum Bumper Supports- (Export Braces)
Front Bumper Brackets- older Regals - 85 (?)
GM # 25517838 and GM # 25517839
1986 Regal T-Type came with one-piece front & rear brackets
ID Codes – on tag in trunk
VD6 –Front
VD7 –Back
http://www.turbobuick.com/forums/general-turbo-buick-tech/71268-bumper-supports.html
http://www.turbobuick.com/forums/general-turbo-buick-tech/47967-lightweight-bumper-j-y-score.html
Aluminum Bumper Reinforcements
Only used on Regal coupes with the turbo V-6 or factory installed Olds 307 V-8.
Hint: 86 & 87 were the only years for the V-8, unless you live in Canada. Look at every 1981-1987 Regal you come across in the boneyard. There doesn't seem to be much rhyme or reason as to when these Aluminum supports were used.
You'll see them on Turbo-T/T-types, base models, Limiteds, 307 or 231 powered, whatever.
http://www.turbobuick.com/forums/general-turbo-buick-tech/188038-junkyard-run.html
Aluminum Rear Brake Drums
83-84 Blazer/Jimmy S/T models
80-84 Buick LeSabre ‘85 RWD
78-81 Buick Century
78-87 Buick Regal
81-85 Buick Riviera
82-92 Chevy Camera
86-89 Chevy full size passenger cars
78-81 Chevy Malibu
78-88 Chevy Monte Carlo
82-84 Chevy S10/S15
80-85 Olds Delta 88
78-82 Olds Cutlass
80-81 Pontiac Bonneville
83-85 Pontiac Bonneville
86 Pontiac Parisienne
82-92 Pontiac Firebird
78-85 Pontiac Le Mans
78-88 GMC Sprint/ El Camino
Easy to ID. They have 1" diameter balance weights welded to them. Usually found on GM's that have alloy wheels and no posi. 3rd gen F-bodies are your best shot. Used on B, C, D, F, G-bodies with the 4.75 bolt pattern.
http://www.turbobuick.com/forums/general-turbo-buick-tech/38556-part-number-aluminum-rear-drums.html
Aluminum Core Support
78-80 Cutlass
78-80 Grand Prix-LeMans
Chevrolet did not install on any of their models.
Note: As far as 71-79 VINS go the 6th character is the year (i.e. 8=1978) on 1980 and newer federal law mandated all manufacturers use a 17 digit format with the 10th character being the year. For example the letter A is used to designate 1980 and B=81 etc. There is no letter O or Q so the year is bumped to the next letter i.e. N=92 P=93 etc with it ending with Y=2000 and again starting with numbers 1=2001 etc.
http://www.turbobuick.com/forums/junkyard-dogs/203568-aluminum-core-support-what-cars-had-them.html
Blazer Front Brake Conversion
Only 98 -05 S-10 blazers brake assembly
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/171079-11-bolt-brakes.html
Bumper Lights
81-83 Buick clear bumper lights- will fit 84-87
Note: 4 doors and wagons had them also
clear turn signals - TurboBuick.Com
C-5 Rear Brake (G-body)2004 Chevy Corvette. Rotors- $85, Calipers/Abutments/Pads- $300, Brake liner shield #12530694- $37.51, Brake kit $290. Price includes L/R. The brake hose and E-Brake Cable from the 1996 Impala SS. This brake UP-GRADE requires disassembly of the rear axle.
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/189213-c5-rear-brake-g-body.html
Coil Packs- 86-87
GM # 25533542
AC Delco # D552
1986-1987 BUICK REGAL GRAND NATIONAL / T-TYPE V6 3.8L 231cid FI T VIN = 7
1989 PONTIAC FIREBIRD TRANS AM V6 3.8L 231cid FI T VIN = 7
1986-1987 BUICK CENTURY CUSTOM ESTATE WAGON LIMITED V6 3.8L 231cid FI N VIN = 3
1986-1987 BUICK LESABRE CUSTOM / LIMITED V6 3.8L 231cid FI N VIN = 3
1987 BUICK ELECTRA LIMITED PARK AVENUE T-TYPE and RIVIERA V6 3.8L 231cid FI N VIN = 3
1987 OLDSMOBILE 98 REGENCY / BROUGHAM V6 3.8L 231cid FI N VIN = 3
1987 OLDSMOBILE CUTLASS CIERA S SL CRUISER BROUGHAM V6 3.8L 231cid FI N VIN = 3
1986-1987 OLDSMOBILE DELTA 88 ROYALE V6 3.8L 231cid FI N VIN = 3
1987 OLDSMOBILE TORONADO / BROUGHAM V6 3.8L 231cid FI N VIN = 3
1986 OLDSMOBILE CUTLASS CIERA V6 3.8L 231cid FI N VIN = 3
1987-1988 PONTIAC BONNEVILLE LE V6 3.8L 231cid FI N VIN = 3
1992 BUICK LESABRE CUSTOM / LIMITED and PARK AVENUE V6 3.8L 231cid FI N VIN = L
1991 BUICK PARK AVENUE / ULTRA V6 3.8L 231cid FI N VIN = L
1986-1988 BUICK SKYLARK CUSTOM / LIMITED V6 3.0L 181cid FI N VIN = L
1986-1987 BUICK SOMERSET / LIMITED V6 3.0L 181cid FI N VIN = L
1986 BUICK LESABRE CUSTOM / LIMITED V6 3.0L 181cid FI N VIN = L
1991-1992 OLDSMOBILE 98 REGENCY ELITE / TOURING V6 3.8L 231cid FI N VIN = L
1992 OLDSMOBILE DELTA 88 ROYALE V6 3.8L 231cid FI N VIN = L
1986-1988 OLDSMOBILE CUTLASS CALAIS SL / SUPREME V6 3.0L 181cid FI N VIN = L
1986 OLDSMOBILE DELTA 88 ROYALE / BROUGHAM V6 3.0L 181cid FI N VIN = L
1992 PONTIAC BONNEVILLE SE V6 3.8L 231cid FI N VIN = L
1986-1987 PONTIAC GRAND AM / LE / SE V6 3.0L 181cid FI N VIN = L
1986 BUICK ELECTRA and RIVIERA V6 3.8L 231cid FI N VIN = B
1986 OLDSMOBILE 98 REGENCY and TORONADO BROUGHAM V6 3.8L 231cid FI N VIN = B
1992 PONTIAC BONNEVILLE SSE V6 3.8L 231cid FI S VIN = 1
1988-1991 BUICK LESABRE / CUSTOM / LIMITED V6 3.8L 231cid FI N VIN = C
1988-1990 BUICK ELECTRA LIMITED / PARK AVENUE / ULTRA / T-TYPE V6 3.8L 231cid FI N VIN = C
1988-1990 BUICK REATTA and RIVIERA V6 3.8L 231cid FI N VIN = C
1988-1990 OLDSMOBILE 98 REGENCY / BROUGHAM / TOURING V6 3.8L 231cid FI N VIN = C
1988-1990 OLDSMOBILE TORONADO / TROFEO V6 3.8L 231cid FI N VIN = C
1988-1991 OLDSMOBILE DELTA 88 ROYALE / BROUGHAM V6 3.8L 231cid FI N VIN = C
1988-1991 PONTIAC BONNEVILLE LE / SE / SSE V6 3.8L 231cid FI N VIN = C
ACDelco Parts
Doors
81-87 G-bodies
Dual Elec. Fan- Ramcharger style
You will want the dual fan setup from a '98 - '04 Dodge Intrepid. I believe all three engine options (2.7L, 3.2L, and 3.5L) had the dual fans. Actually any '98 and up Chrysler product will do - Intrepid, Concorde, LHS, 300M.
http://www.turbobuick.com/forums/general-turbo-buick-tech/255882-dual-fan-kit.html
86-87 ECM
GM #1227148
Here is a listing of all that use it:
Note: Turbo Regals use different chips; don’t use the chips from these cars on you GN!!
1989 PONTIAC FIREBIRD TRANS AM V6 3.8L 231cid GAS FI T Engine VIN = 7
1989 PONTIAC FIREBIRD TRANS AM GTA SE V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL LIMITED V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK CENTURY CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY ESTATE WAGON V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE CUTLASS CIERA S V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE CUTLASS CIERA V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA PARK AVENUE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK LESABRE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE 98 REGENCY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE 98 REGENCY BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK REGAL T-TYPE V6 3.8L 231cid GAS FI T Engine VIN = 7
http://www.turbobuick.com/forums/hot-air-non-intercooled-tech/33080-basic-hotair-info.html
F-body Radiator
OEM replacement Radiator for a ’87-’92 Camaro with V-8
TurboBuicks.com - Upgrade To The F-Body Radiator
F-body Sway Bar
Late '80s - early '90s F bodies (Camaro/ Firebird) Z28, IROC, Trans Am.
They come in different sizes, 36mm is the largest.
Moog makes bushings to install on the G-body.
Note: The hollow bars only came on 3rd gen Camaro/Firebirds that came from the factory with 16" tires. In other words don't waste your time looking in the V-6 powered cars.
http://www.turbobuick.com/forums/junkyard-dogs/292798-what-cars.html
Front Frame Braces
GM # 472169 and 472170
Any 81-87 Cutlass , Grand Prix and Monte Carlo SS.
The Malibu’s only got the braces if it had RPO 9C1 (Police Equipment)
The really odd thing is the Pontiac Grand Prix from those years.
From the factory, it had the cross brace, angle braces, and under hood braces, ALL the body bushings (even the "GNX" bushing), AND the back seat had the same angular stamping welded in that the GNX got.
They were the most solid G-bodies you could buy.
brace
http://www.turbobuick.com/forums/general-turbo-buick-tech/120820-front-frame-braces.html
Header Panel
1984-1987 Regal
Hydro-boost Brake Booster
84-85 GN's Power booster, Master cylinder, Hoses
Hydra-boost and Power-master use the same pedals. Those of course are different than the vacuum booster pedals.
Any Hydra-boost from a G-Body will work. Turbo or Diesel. The 83 carb-turbo was also Hydra-boost. I guess you could say plug and play assuming you have the PS and Hydra-boost hoses figured out.
A1 Cardone hydro boost #52-7211
A1 Cardone master cylinder #10-1984
pump to hydro boost hose #91660
hydro boost to gear #71187.
http://www.turbobuick.com/forums/br...heels/292004-hydroboost-install-question.html
86-87 Ignition Modules
GM # 25526449
AC Delco# D1996
1987-1988 BUICK LESABRE CUSTOM / LIMITED V6 3.8L 231cid FI N VIN = 3
1986-1987 BUICK CENTURY CUSTOM ESTATE WAGON LIMITED T-TYPE V6 3.8L 231cid FI N VIN = 3
1987 BUICK ELECTRA LIMITED PARK AVENUE T-TYPE and RIVIERA V6 3.8L 231cid FIN VIN = 3
1987 OLDS 98 REGENCY and TORONADO / BROUGHAM V6 3.8L 231cid FI N VIN = 3
1986-1988 OLDS CUTLASS CIERA and DELTA 88 ROYALE V6 3.8L 231cid FI N VIN=3
1987-1988 PONTIAC BONNEVILLE / LE V6 3.8L 231cid FI N VIN = 3
1986-1987 BUICK SOMERSET V6 3.0L 181cid FI N VIN = L
1986 BUICK LESABRE CUSTOM /LIMITED, SKYLARK CUSTOM V6 3.0L 181cid FI N VIN = L
1986 OLDS DELTA 88 ROYALE V6 3.0L 181cid FI N VIN = L
1986-1987 OLDS CALAIS, SUPREME V6 3.0L 181cid FI N VIN = L
1986-1987 PONTIAC GRAND AM V6 3.0L 181cid FI N VIN = L
1986 BUICK ELECTRA, RIVIERA V6 3.8L 231cid FI N VIN = B
1986 OLDS 98 REGENCY, TORONADO BROUGHAM V6 3.8L 231cid FI N VIN = B
ACDelco Parts
Jounce Bars (Diagonal)
Any 81-87 Olds Cutlass or Pontiac Grand Prix and 83-87 Monte Carlo SS.
The really odd thing is the Pontiac Grand Prix from these years.
brace
http://www.turbobuick.com/forums/parts-sale/267137-34-hollow-sway-bar-frame-braces.html
License Plate- Stay Down Door
GM PART # 14083879
CATEGORY: Fuel Tank Filler Door
82-92 Camaro
Also comes on '80's Caprices and similar model lines of GM vehicles.
http://www.turbobuick.com/forums/parts-wanted/172531-stay-down-gas-door.html
LS1 Brake Mods
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/172762-ls1-brake-mod.html
LT-1 or LT-4 Mini-Starter
LT1 Starter, GM #10465293 –AC/Delco# 323-488
ACDelco Part #323-488
Description: STARTER, (REMAN)
Year Make Model Engine
1997 CHEVROLET CAMARO Z28 V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1997 PONTIAC FIREBIRD FORMULA V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1997 PONTIAC FIREBIRD TRANS AM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER LIMITED WAGON V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET CAMARO Z28 V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 PONTIAC FIREBIRD FORMULA V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 PONTIAC FIREBIRD TRANS AM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET CAMARO Z28 V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
LT4 Starter, GM part # 10455709 – AC/Delco # is same as GM.
ACDelco Part #10455709
Results 1 to 10 (10 total)
1996 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = 5
1996 CHEVROLET CORVETTE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET CORVETTE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CORVETTE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1993 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = P
1992 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = P
1991 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = 8
1990 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = 8
1989 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = 8
1988 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = 8
1995 PONTIAC FIREBIRD FORMULA V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 PONTIAC FIREBIRD TRANS AM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
http://www.turbobuick.com/forums/general-turbo-buick-tech/273456-mini-starter.html
LT1 Mini-Starter Bolts
LT1 Starter Bolt # 14037733 and Bolt # 12338064
http://www.turbobuick.com/forums/engine-tech/274662-lt1-starter-bolts.html
Posi- Rear Axle
Look for G80 RPO code.
You can find the 8.5" with 3 series carriers in 77-87 Caprice and Impala. Look for cop cars and station wagons. Other RWD full size GM's too. 87 and older 1/2 ton trucks as well. Look in the 80's trucks with overdrive auto trannies as those always have 3 series gears in them. Double check the axle spline count. You need 28 splines. Around 87-88 GM went to 30 splines. I have found that cars and trucks in the Snow Belt are your best bet for finding a posi carrier. Damn hard to find where they aren't needed.
http://www.turbobuick.com/forums/general-turbo-buick-tech/190995-rear-end-help.html
Rear View Mirror- Compass/Temp Conversion
Gentek 31 Compass/Temp mirror
Check under Gentek or Donnelly mirror and should be able to find some info
Usually found in various Caprice, Impala SS, Roadmaster, etc.
http://www.turbobuick.com/forums/junkyard-dogs/269050-homelink-out-j-y-retrofit.html
Gentex NVS Compass and Temperature Rear View Mirrors
Speedometer- 140 MPH
83 Riviera Indy Pace Car Replicas. They only made 500 of them and it was the only model to have that 140MPH speedometer in it.
http://www.turbobuick.com/forums/junkyard-dogs/225605-140-mph-speedo.html
Under Hood Braces
86-87 Monte Carlo SS
brace
Under Radiator Brace (Cross brace)
Any 82-87 Grand Prix
Vacuum Brake Booster Conversion
86-87 Monte Carlo Double Diaphragms
Non-turbo Regals
Carquest # 54-71243
Get the double-diaphragm type vacuum booster like what the 86-87 Monte SS used. I know most of the vacuum brake G-bodies from 79-87 used the same unit, but specifying it to the guy behind the parts counter lets them pick it out from the computer easier. I think mine was part number 50-1243 from AutoZone. $200 -- order it with a master cylinder.
Vacuum Brake Install 2
Powermaster To Vacuum Brake Conversion
One more thing I found out yesterday is that some of the Cutlass' have a front aluminum bumper support as well. We were stripping a Cutlass to make a dirt car out of and I found that the support was aluminum and tried in vain to keep it so I could see if it would fit the Regal bumper. I may still get it back so I can check but this would be great if it either fits or can be modified to fit.
And yes, We saved a bunch of parts so they'll be posted later. We couldn't save the windshield though, it was cracked.:frown:
oops... one more...
Alternator bracket-- for 86-87 alternator on 84-85 GN conversion
GM # 25503134
Was used on all 1981-1987 RWD Buick V-6's. Can find them on a lot of the 4.1 V-6 cars and it appears they may have been part of the gauge option on the 81-83 cars. Look for the voltage gauge on the right rear corner of the cluster and it’s a sure bet that it has the bracket.
http://www.turbobuick.com/forums/ho...-140amp-alternator-solution-hot-air-cars.html
http://www.turbobuick.com/forums/hot-air-non-intercooled-tech/157895-alternator-upgrades.html
Hey Guys, i just bought a Center Console off a Cutlass from eBay. It is full length WITH an armrest. I am going to re-use my bottom half and paint the top gray OR maybe black. It looks like it should fit... just fyi. here is a pic:
Not looking for praise for compiling the list in the "sticky" above--Thank the guys that provided the info in the links!! This list just provided me a way to clean up my "files" :eek: would be nice if we can keep the "list" as useful info and post comments here or something... my .02
