Turbo6Smackdown
- Dec 31, 2005
As you all know by now, I have a few problems I'm chasing with this car. The two biggest ones, that I'm now starting to think aren't related, are a lean idle, and a super rich everything else. My idle's like low 14's (afr) but it loves a high 12 idle. It idles almost like a stocker at that AFR. As far as everything else, I'm shooting for the quintessential 10.8 AFR. At present I'm runnin' a stock maf, tt 91 street chip and powerlogger just for diagnostic purposes. I normally run a TT or Bailey alky chip with plastic LS1 maf & gen 2 translator. When I removed all the fancy stuff my idle really got a lot better. A little lean without the translator's abilty to add fuel but none the less a ton better. Odd...
As far as the idle there's nothing left for me to do to change that. I hear the idle fuel's in the chip and that's that, but I could certain pull fuel in WOT, but for me personally, having to pull like 8% or more in wot fuel tells me that there's a problem, not a chip burn mistake. I'm not comfortable with say a 9% fuel pull band-aid on my shit. That doesn't let me sleep at night.
Do you guys think this lean idle/rich everything else is related? Or two separate and distinct situations. Could a bad O2 sensor cause both? I always thought the O2 sensor was for like light cruise and light cruise only, where idle & wot is chip controlled. So to my mind the O2 can't be the culprit for a one single cause of both issues.
