Made my own and 1 other member had me make him a set. These are weld on but to do it right the frame must be out of the car.
View attachment 211994 View attachment 211995 View attachment 211996
No pan hard bar Rob, and the rest of the mods to the frame will not be shown, except to a very few. If you want to find out almost all the mods to the frame look in the B4black section and the title is "Finally got some time".Can you post a pic of the completed setup with suspension in the car??
I was wondering if you have a panhard rod or locating bar to center the rear housing also.
ive been in the 10's looking for a lot faster seen no need
If no bracing is used eventually you will rip the brace off the frame. Not only does it rip the bracket off the frame but it will go through the floor and through the rear seat bottom. Saw it with my own eyes. could not believe it
I saw the car at ANS Performance. I dont know how fast it was but it went right through the floor. I welded in the hr kit shown aboveAt what ET does this become an issue?
Does this happen at about the same ET that wrinkles quarter panels?
if you don't want to weld brackets, you can buy the connecting arms that do a similar thing but not as good. they connect the upper fronts to the lower fronts is all. seem to work. but anybody running 11's and faster should be concerned.
How thick are the plates used in these kits?
Thank you for the update! I was curious if they were the frame thickness as the frame, or a bit thicker. (11ga or about 1/8")1/8"
