I'd like to comment on a few of your thoughts
now theres a product named ZDDP?
---------its not named ZDDP-----its ZddPlus-----
"Why not just use a product WITH ZDDP"-------because most of the oils that contain adequate amounts of zddp have other characteristics that make them less than ideal for our cars according to the original requirements specified by the manufacturer-------with the exception of higher priced "exotic oils" that cost much more than conventional oils
"I got about 2mpg better mileage with royal purple"-------while i certainly believe royal purple is good oil i have to wonder-------are you sure about the calibration of your odometer or your math???-------considering that the API rates oils as energy conserving if they can extract a mere 2% in mileage increase that seems pretty amazing-------the fact is that even then most of the savings is due to lower viscosity ratings that reduce pumping losses and not actually friction in the bearings----------in several daily driver GNs consisting of various amounts of city and hwy driving i average in the 20 mpg range-------2 mpg would amount to a ginormous 10% increase-------i doubt any reasonable person could believe that-------i do believe if that were even close to true that GM, Ford and virtually every other manufacturer would quickly make "royal purple" factory fill cause that would be the single most cost effective mileage increase since the introduction of CAFE ratings--------and the API would certainly make a "class all of its own" for "super-duper energy conserving"
"Mobil 1 drained out like tar after 4000. That means the oil is burning"-------Mobil 1 like tar?????--------in the last 20 years i have run hundreds of gallons of Mobil 1 through my personal cars including many of my several dozen GN's and i have never witnessed such a thing------doesn't seem possible since the high temperature rating of Mobil 1 is easily the equal of any other synthetics-----the ability to handle extremes of temperature at the high and low end is the single greatest attribute of synthetics to begin with-------if Mobil 1 could not handle the temps of a GN then there is virtually NO WAY that any one could even consider a conventional oil in a GN and we all know that most GN's are run with conventional oil with no problems and they were in fact originally specified from the factory to use conventional SF oil
I dont have a varying trip distance, and last i checked, a gear driven speedometer doesnt have a slipping clutch last time I checked, so its not like the odometer can "vary". I drive the same route to work and back every day, and thats all I drive with this car. My results are not in a vacuum...many people can attest to it. A year later I am still seeing the mileage benefits. Moly is one of the most "slippery" substances on the planet, and fills microscopic voids throughout the engine...this can increase your oil pressure..it can increase compression, etc....not a wives tale..its absolutely true. RP has ALOT of moly and is one of the main reasons Ive used it for 8 years. I used it in my cobra and beat the living hell out of it...7500rpm powershifts with 600hp in the dead of winter without warming the engine up AT ALL, and the engine was like new when I sold it with 60,000 miles on it. And in those 60,000 miles and 5 years, I did 8 oil changes with 8 filter changes. When I drained it after 8-10,000 miles, it looked almost new and didnt smell burnt like the mobil did. When I say "tar", its a JOKE! It drained out black and filthy and thick and had seen better days. I used Mobil soluble oil in my CNC's and its the worst crap on the planet. It went sour/rancid within a couple weeks every time and the blending was terrible. It would seperate into clumps as delivered and just sucked all around. The fact it comes from Mobil, doesnt mean its the best. It means it has tens of millions of dollars in marketing power behind it. Ive used many many different oils out there and Ive only posted what Ive seen. I usually have to change the oil in my GN every 4000 miles or so, and by then Ive burnt through 2 quarts...and thats with a decent oil like "Q" high rpm or valvoline SYN. The last change, I used Royal Purple and went 10,000 miles without changing my filter, topped it off with 2 quarts, and it drained out looking almost new, and without any carbon or soot buildup under the valve covers like other oils have always done to me over that time period. Redline is an EXCELLENT oil. So is royal purple. Valvoline SYN, Quaker State "Q"'s are great....
So you're trying to say that the turbo buick requires a "special" formulation of ZDDP? Telling people they need something unique and special when for years they havent needed it, is always the first trick to scare people into buying a product. Ive put 55,000 miles on my TR in the past 3 years without a special ZDDP formula. People were freaking out about wiped cams, and instead of believing everything I read on the internet, I did some research. I UNDERSTOOD the problem...not carrying on a wives tale. I found out about ZDDP 3 years ago and made sure people on this board knew about it and I made sure to keep it in my oil....and all I did was run oils that already have plenty of it. All the engine..I mean all the CAM and lifters need is a sacrificial layer to prevent the metal from wearing on metal. Why did they used to use lead in gasoline? To save the exhaust seats. It was a sacrificial layer that was used to keep the exhaust seats from wiping out, because back then the valves were riding right on cast iron...no special seats like today. Telling people that the great oil Armageddon is right around the corner and your product is the only thing they can use to prevent catastrophic engine failure, by telling them that all ZDDP everywhere will be removed, which is flat out false, by simply scaring people into buying it, is not the way I would have done it. If you say that this product has all the ZDDP you need and will allow you to run any oil you prefer...I can see that. But saying everyone will be removing it when its not true at all...well you get the point.
