TOOMANYTOYS
- Oct 18, 2003
I am in the middle of swapping my oem steering shaft out for a jeep shaft and comparing them side by side the jeep shaft is about 4 inches longer. Is this right? How do I get it to fit?
I had same issue. Stay with it it will work. Collapse the shaft to where it is seperate again then turn steering wheel to where it is centered. Then using the gear box or wheels center those. It took me a few times to get it right but it finally was centered. Its been a while since i did it, but i remember these issues. I even had to pull one of the things off of the splined shafts and rotate it to get mine to work.After a few good shots with a hammer it freed up and I was able to collapse it no problem. The only issue now is my steering wheel is no longer centered. I think that my new steering box is defective though.
More is better I guess.also makes kirban more money....although I cant take credit for the idea other companies ell them also.
