was just wondering were id be car is in great tight running shape!! ill just list mods done to car if i dont list it consider it stock
61bb turbo
cottons front mount
alum rad and dual fans
alky
60 injectors turbotweak chip
62mm ported throttle body
lt1 valvesprings
double roller timing chain
adj regulator
3inch dp open dump
3inch cotton exhaust
external wastegat tnetics
hotwired walbro pump
air bags upper and lower southside bars
hotchkis front sway bar
built tranny non lock up 3500 stall convertor
external tranny cooler
has other thing breathers valve cover k and n intake
didnt do yet but have a ls1 maf rdy to go just need translator
i just need some stickies never had it down the track but i know how to build boost no getting it to hold we will see i have line lock for burnout...also what else can i do to make car fly
o ya not sure what timing is at the moment but i do run car hard have scanmaster low 800's on the 02 no knock and run 26 psi on a chill night
61bb turbo
cottons front mount
alky
lt1 valvesprings
adj regulator
3inch dp open dump
