View attachment 221099 I have never done this and found it challenging and time consuming, but its done. I am not a professional welder or fabricator but have a craving for power. I found that the Turbo does spool up faster. Welded everything up with a mig welder using flux cored wire. It is all welded and is not a 2 piece design but once the up pipe is removed there is plenty of room to change out plugs and easily remove the valve cover if needed. I also cut the original cast iron elbow and used the flange with the pluck and turned the welder on full power and zapped it a little at a time and it held together good. Spent about $90 bucks on the pipe. Now my turbo has that cool whistle sound! Hope this is helpful to someone.
View attachment 221093View attachment 221095
