I will have to post some more pics of the rear. Dusty, it is lower than last year by an inch. It is stock suspension with a DTS dana 60. I have wolfe lowers and DTS uppers. I use a 150lb 10 inch 2.5 diameter QA1 spring in the rear. In the stock location. The trick is the Mini tub. All that is left of the rear frame over the axle is the inner skin. My chassis guy built a 1.5 inch tubular inner frame that follows the stock frame and ties into the cage. This allowed me to put a 10 inch wheel with 6 inch BS under the car. I use a 295 radial also. I had to re drll the lower mounts on the rear end because when I lowered it, the bottom bars were pointing down at a 7 degree angle. I flattened them out to a 2 degree angle. I moved the lower shock mount in an inch or so. I also run a HR Parts N Stuff anti roll bar. It is the nutz. I"ve been a 1.27 60 with it. Not bad for a 3500 lb boat. It is a non intercooled 565 chevy with an F2 blowing through a C&S carb. As I said before, the 8.32 at 166 was my best pass ever. Anyway, once I figure out how to post pics I'll do it.
These pics are before I lowered it another inch or so and before I put on Weld alumastar double beadlocks.
Thanks,
Jason
