T turbobooster Active Member Joined Nov 12, 2002 May 1, 2022 #1 The last post I see is in 2018 is this still a fitment issue with this DW 300 pump?
BEATAV8 The Engine Whisperer Joined Feb 14, 2002 May 3, 2022 #2 turbobooster said: The last post I see is in 2018 is this still a fitment issue with this DW 300 pump Click to expand... What kind of issue are you having? DW will make the bottom of the pump smooth if you ask them too, or you can smooth it out yourself with a dremel tool.
