joed
- Mar 6, 2002
Scary.
I wonder if some food coloring would be a go to? Might leave some evidence once the alky evaporates.so I never saw a drop, had no indication that anything was wrong until I saw the lower pressure and neither did they.
I guess that is a good hint to buy the stuff in 5 gallon cans, sealed from the mfgr....Many times pump failure is from the fuel supplier using one pump for all the race fuels. This results in the meth getting contaminated and the residual oils and such from the other fuels kills the diaphragm in the pump.
hey chuck, what kind of fitting did you use to put transducer into, did you put it in the line going to nozzle to inlet pipe ?Here's the place I got my transducer from.. $22.00, FREE ride.
http://www.ebay.com/usr/renbusan?_trksid=p2057872.m2749.l2754
here's the 10' cable for $10
http://www.ebay.com/itm/Wire-harnes...0-3-meters-long-UL-listed-wires-/261279660259
Going to order 1 for the 87.
Yes, very scary and I see that a lot. Testing it each year is very important and logging it with a pressure transducer through Powerlogger or FAST is even better. One other thing you can also see with the tester is how long it can take to build up pressure on an alky kit thats been sitting for a while. Thats why its so important to keep it primed before you step on it.
Its great to hear some stories of pumps being 8 years old and still working great.. but there are too many variables like fluid being used, temps the vehicle stored/sits in, simple quality control for the pumps MFG when the diaphragm was injection molded, use/lack of use.. its a chemical after all sitting.., etc.
Testers are great, the more jacked up the boost and dependance on the kit, the more aware the user needs to be aware of systems in the car. Not only meth but fuel. Thats why cars running 100% I suggest every couple years get the pump serviced. Most simply wait till they see a noticeable leak and then deal with it. Like changing oil, they wait till rods start knocking then deal with it. its 80 bucks for a rebuild... 40 per year in cost.. thats 3 bucks a month.
Think of it like salt water and a boat. It just sits there.. you dont ride the boat.. but a few hours every few months.. come 2 years latter the whole thing has gone to hell from sitting in the salt water. Want the pump to last forever.. Sunday drain the kit and fill with washer fluid.. On Friday, pump the washer fluid out.. fill with methanol.. use the car and then Sunday drain and refill with washer fluid. So the pump is always sitting in washer fluid.. problem is nobody want to do this.. given the 80 it costs to rebuild
The blessing is even if it does leak, its still putting alcohol into the engine. Not the complete amount, so if the car is simply setup with a little more meth than it needs when tuned, and the pump does decide to leak, no harm no foul.
Methanol is not a violent chemical. Don't believe me, get some and put into a dish and throw a match into it.
