I am installing my 3 bar MAP sensor, and leaving the 2 bar intact. I'd like to run the signal wire into the passenger side near the ECM, but it is being a PITA. I've tried my normal coat hanger trick pushing the wire through the factory loom, but no luck.
Does anyone have a trick or tip for running a wire into the passenger floor board area? There's not much room to work under the hood in that area because of the a/c.
This is where I was trying to go through
