Good2win22
- Nov 28, 2012
Ok fellas, here's the deal.... Stock 87K BRF transmission shifts completely normal under daily driving conditions. When under WOT, transmission will sometimes shift normally at around 5000 RPM and most times it will not shift until I get off of the throttle. Then getting back to WOT, it will down shift and repeat.
TV cable is adjusted accordingly and I've checked the spring on the governor and it's intact. Fluid and filter has recently been changed. No burnt smell and I went with the dexron vi.
Could the TV cable be over riding the governor? If I take a few clicks out of the cable adjuster, the car shifts early and quite sluggish.
Any thoughts are greatly appreciated!
