I would also take into consideration the durability of the TA head if you might ever step things up in your combo you won't have to worry about cracking with the TA heads.
The latest version GN1s don't crack...it's the earlier versions (forget which years). I ran a set of GN1s for 3-4 years out of the box and no problems. HUGE difference between those and stock heads unported. I went from 11.50's to 11.00's on the same turbo by just switching heads.
If I had it to do over again with mods on my car, GN1s would be at the top of my list. My car ran 12.6's(108mph) at the track with a stock turbo on pump gas(no alky) with them at 16lbs of boost. Just drove to track, put on slicks and ran. Plus, Tom has always been great to deal with as I have drove down to drop off/pick up heads at his shop several times having them freshened up on rebuilds. He did the work himself on one occasion.
