alliedmike
2 Cyl short NO PROBLEM
- Jun 9, 2009
I tried to search this on here but came up empty on an exact answer, I have a set of fans out of an intrepid. I am trying to figure out the wiring on it, according to mitchell blacks are ground green is low and yellow is high, well green is the same speed as yellow but green and yellow together are high does this sound about right? i dont want to burn anything out mitchell says green low and yellow high but if you look at the schematic you cant tell if they are calling in yellow and green at the same time for high anyone deal with this first hand? thank you in advance
