meanchicken
gallo vicioso
- Oct 6, 2007
OK...this is on my nerves. I need to solve it before the 31st because I'm going to the track to finally find out what kind of reaction, 60, 1/8, 1/4, mph I can eek out.
I've also been smack talking a couple Camaro buddies so I have to be there to put up or shut up.
When the engine is good and warmed up (180-210) this gremlin occasionally shows up.
The car runs, drives and idles normally, but as I lightly accelerate under part throttle and light boost (approx 5lbs) the engine will cut out real quick....sometimes one...sometimes 2-3 times back to back, and the check engine light will blip for as long as the cuttin out takes place. If I continue driving, the problem will come back and go away....it might be gone for a couple weeks, a couple days....or do it the next day....
At WOT it pulls good, but if it catches me going to WOT (rolling into it) and does the cut-out, I'll get a slight pop outa the intake. It did that today, so now I'm writing.
It seems to be igition related.
02's are good, fuel pressure is good, TPS is good, IAC is good (at keast at idle it is), volts ar about 13.2 with the headlights on and 13.4 without, new plugs, new wires, what else can I tell ya.
Help please!
Coil pack?
Ignition module?
ECM?
Alternator?
Thanks!
Tim
Help please!
Coil pack?
Ignition module?
ECM?
Alternator?
Thanks!
Tim
