loland, you say you're an interior guy......sure
Hi,
Do you have the seat tracks already? if No - you will have to order those from Recaro.
If so, Then all you need to due is call Recaro or go there website and find the style (model) seat you have and tell them you need the bracket to fit the GN and I think the correct part number for those brackets to fit the Buick G-Body's is # 81182.
I would also call SUMMIT and ask if that seat bracket (8112) will also fit recaro. (I seem to think it will).
The 8112 brackets Also fit:
Buick: Centry 78-87 (driver & pass), Regal 78-87 (Driver & pass), Chevelle 78-87 (driver & pass), Malibu 78-88 (driver & pass)..
Scot W.
Everything is holding up just fine! Nothing I would have done different at all, and it's been driven over 3,000 miles and also autocrossed, drag raced and Still won first place in a show too... :biggrin:Hi scot, how about an update on the interior? How is everything holding up? Anthing you may have done different? Has it been driven much?
THANKS!
Nope! Still not even a scratch on either the steering wheel or the shift lever. No I never used any clear but wouldn't mind trying it in some spots. The Only place where there is scratches are on the console where the seat belts keep rubbing against the console. I thought of sticking some low gloss clear plastic film in those areas but the clear would be MUCH easier.I work at an upholstery shop and we use SEM stuff once in awhile. Nice stuff. I kinda want to try the stuff that you use in a paint gun. I dyed a few pieces in my old Neon with a charcoal color and used a low-gloss clear. Can't even scratch it with your finger nails.
Scot, I'm guessing you dyed your steering wheel/shift knob as well. Any issues with the dye rubbing off? Did you use the clear coat at all?
The clear coat is SO nice! You can put as many coats as you want! I put like 5 coats on my stuff and it had a nice low-gloss sheen to it. Very nice stuff. I'm sure the seatbelt area will still rub somewhat, but that's just something you might have to touch up once in awhile. Guess it's the name of the game palNope! Still not even a scratch on either the steering wheel or the shift lever. No I never used any clear but wouldn't mind trying it in some spots. The Only place where there is scratches are on the console where the seat belts keep rubbing against the console. I thought of sticking some low gloss clear plastic film in those areas but the clear would be MUCH easier.
Scot W.
