Intercooler shroud?
V8Killer
GM speed junkie
I have a spare stock GN shroud kicking around. Will this fit the TTA? Looks like it would be really close by the fans.
Does fit have one on mine! Without the other dam pieces you'll just have the cup of the opening of the shroud.
My TTA scoop somehow got ripped off my car, and I found a GN scoop in mint condition for pretty cheap. The easiest way to get it on the TTA is to leave the TTA intercooler bolted up, take the GN scoop and force it behind the dual fans, then I cut the corners of the top of the gn scoop to bend it a little, then bolted it on to the scoop. The GN scoop hangs a little lower, but hey, its flexible plastic, and its easier then locating a TTA scoop and easier then fabricating one, if you need help let me know and i'll take some pics.
Good luck.
~Murt
