Yes they are. They're rated at 97.4 lb/hr @ 30 psi. They are rated using gasoline. A solenoid controls flow to the nozzles. The ECM controls the solenoid. The ECM is programmed to open the aux fuel solenoid at 8 psi.If I see correctly those are constant flow injectors aren't they?
When it comes to my disfunctional fuel system, there is no such thing as a dumb question. My fuel system is as unique as my intake.This may sound dumb but couldn't you put a third electrical pump and have it turned on at a higher boost level? That would give you the extra fuel without the mechanical pump and you could taylor it to different presures, or am I being a little ignorant.
I'm sorry. You lost me. Could you be more specific?It seems like you'd benifit from three, using the solinoids to block the siameesed fuel line. For the constant presure ones you split the suply and the first one comes on a 8 psi and the second comes on at a higher presure to get rid of the lean issue.
I think I understand. The idea I had for the second fuel pump and system was to run a regulator for that system that referenced at a higher value than the 1 to 1 that is used on the electronic fuel system. The reason for using the 1 to 1 on the electronic system is because the electronic injectors are picky about how high a pressure they can operate at and still deliver a consistant pw. The mechanical nozzles are not as picky, so I can run a different reference value with the second regulator.Don, If you have 2 different presure switches that will activate at different presures you can take and use the solinoids as presure blocks on the fuel lines and put 2 lines into the constant injectors. This would allow for a higher presure after say 15-20 psi. That would give you 2 different pumps and you could run seperate presure pumps to get rid of the lack of fuel you need to get what you're after. Granted you need 3 pumps to do it but it shouldn't be a problem. You could even use relays to trigger the pumps so they're not running constantly.
I'm thinking the fuel pressure regulator that I will be using with the secondary fuel system is going to be a very important tool for getting the fuel delivery curve I need. Two important variables to play with will be the initial fuel delivery pressure at the activation point, then the ratio of the reference value as map increases. The overall curve can be raised or lowered by the base fuel pressure adjustment, and the steepness of the ramp up of pressure can be changed using different pressure reference ratios with the regulator.I think I understand. The idea I had for the second fuel pump and system was to run a regulator for that system that referenced at a higher value than the 1 to 1 that is used on the electronic fuel system. The reason for using the 1 to 1 on the electronic system is because the electronic injectors are picky about how high a pressure they can operate at and still deliver a consistant pw. The mechanical nozzles are not as picky, so I can run a different reference value with the second regulator.
I really appreciate the feedback from all of you. The system I just described is actually something that I've figured out through this last bit of discussion. It seems it's pretty straight forward, and easy to setup. You guys are great.
They put me to work at the shop, imagine that, so the toy is on hold until I can get caught up.So what are your plans, any updated pics?
Don, Why not just use a barrel valve and use a boost can to move the barrel valve. Old school but could be effective. That way, you can buy the needed parts and use a wastegate actuator to move the valve. You could even use an electronic wastegate controller to fine tune it. Kinda like giving a caveman a wrist watch. I am a little concerned about the reliability of a pressure switches, we even have them go bad in the aviation world. By using a barrel valve, you can mechanically control the fuel to your secondary system.
Have you talked with the folks at Kinsler? or some of the other old school methanol guys about what you are trying to accomplish. Alot of the old school guys like to play on the far end of the spectrum. I understand that Kinsler likes to think outside the box. Might want to give them a call, if you haven't already.
Don, I think turbofabricator just called you a caveman. LOL But the barrel valve just might work.
Donnie, we've never met but I would sure like to shake your hand. I've never seen a finer example of craftsmanship. You, sir, are the bomb. If that Buick thing doesn't work out, perhaps you could could whittle the next space shuttle out of a hunk of billet with your table top mill. I salute you, even though I'm a mere mortal.
