I know that over time these original alternators simply fail.
Has anyone ever had one partially fail?
My car typically sits for about 2 weeks at a time, and if I neglect to start it up during those 2 weeks the battery usually needs a jump.
After that, everything operates normally.
And if driven or just started every couple of days, there's no issues with battery.
Last weekend, it needed a jump.
Drove it about 10 miles and after turned car off it had no electrical power at all.
Turn key & no crank, no power at all.
I got a jump, jumper cables on for about 2 minutes and I noticed the Voltage trouble light was on when it started.
Never seen that Voltage trouble light on before.
It had stopped cold again by the time I disconnected the cables and put them back in the trunk.
Got another jump, jumper cables on again for another 2 minutes.
I got in the car right away in case it stalled again.
Voltage trouble light on again.
It started to sputter a little, throttled up in Park and still stumbling.
I'm pretty sure that the Tachometer wasn't even moving that time; and it stopped cold again.
Brought it over to local garage and they determined alternator gone bad.
They said would fully recharge battery.
So it's been sitting since Thursday or Friday while I'm waiting for parts.
I stopped over earlier tonight to get some gear out of the trunk and noticed interior lights and trunk light at full strength.
I forgot for the moment that they had fully charged the battery.
But then I started the car and it turned right over, full power. and no hint at all of any trouble.
I let it idle up to about 180 temp. and shut it down.
Then started it again immediately, again running normally, no stumbling at all.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
