C castrolgreen Member Joined Jun 19, 2011 Aug 11, 2014 #1 how do I verify ignition timing with powerlogger at idle it shows about 23 24 is that correct
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Aug 11, 2014 #2 I believe there is a way to lock it at 15* and put a timing light on it . Do some research
C castrolgreen Member Joined Jun 19, 2011 Aug 11, 2014 #3 yeah I seen that method...so what is the logger stating is there anyway to pull up the chips setting on the logger
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Aug 12, 2014 #4 I have a SD2 chip so I can make adjustments not sure about other chips
C castrolgreen Member Joined Jun 19, 2011 Aug 12, 2014 #5 ttt thinking about getting an SD2 chip but want to know what I have first my logger will sometimes show 19* degrees timing advance but floats mostly around 22 23?????
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Aug 12, 2014 #6 http://www.turbobuick.com/forums/threads/verifying-ignition-timing.377617/
