But is the voltage making it to the fuse panel when the ignition is turned on?
No voltage to the fuse panel is a different problem than the ignition switch not turning the motor over. There is a small wire in the same harness, I think it's purple, and it goes to the starter solenoid. This wire also may not work if the steering column section down by the instrument cluster isn't in the proper position. The reverse lockout could be keeping it from starting.
