ROTTWEILER
- Nov 9, 2006
If I drop the oil pan will I be able to see the the timing chain tensioner? Not sure if there is one, believe the motor had a double roller installed and I'm now worried a tensioner may have been used with it. I read somewhere on TB the double roller will grind it up. Pulling the pan seems alot easier than removing thr front cover. Any advice you guys offer will be appreciated.
