Low Budget
- Apr 10, 2002
Jim,
I could have the minimum air set too high and end up at 0 but I don't. The counts are not always at 0. As a matter of fact, more often than not, the count is above 0. It could be at say, 12 and just sit there unchanging unless I step on the gas. Then it will go up to much higher numbers depending on how hard I'm on the gas. (Is it supposed to do that?) If I don't touch the gas, it could be sitting at 12, and then as described above, the rpm's will mysteriously start to drop. The count will stay steady and unreactive to what is taking place. It could (although usually doesn't) even shut off it can drop so far. Still no change until it is gone. Then the number changes!
Jeff
(I responded to your mail too Jim.)
Jeff
