Help, tried all the ajustments but still cant get better than 57 on the IAC readings. TPS is .46 at idle. Car runs a little better but still drops off to about 650 RPMs when lifting the throttle.
Make sure the car is good and warmed up each time, otherwise you may have trouble setting the base idle. I'm assuming you cleaned the chamber and IAC motor.
Keep working it... if all your hardware is functioning, it will work out. Let us know how it goes.
