Hi, I have read on a few other posts and I know one was from Cal where tuning goes fine up to a certain boost then no matter what, you are maxxed out whether it be fuel pump flow/ fuel line size or injector size. Please see signature below for combo. Well my story is: with the below combo car tuned as it should with an ACCELL DFI up to 20 psi boost then at 20psi AFR on wide band went to 11.6AFR (gas scale) No matter how much I added in injector Duty cycle it stayed until I maxed out the injectors. I have a set of Delfi 75's in it now. I also have a new set of 63'3 and 83's. I am going to sell all 3 sets and buy a new set for my car. Sorry it took so long to get to the question but here it is: I plan to run this setup to 30PSI boost. Based on sig below what is the consensus of the size injector to buy. I am currently changing to a classic fast also What is the largest injector you can run and retain good idle/streetability control especially if I need to sometimes change back to a gas tuning map. Thanks :biggrin:
