ok im not sure if these go anywhere because i labeled most everything pretty well but im going to make sure...
the first one is a brown plug it comes out of the harness with the other wires going to the relays or whatever that are mounted on the passenger side inner fender. it has a black wire and a black/white wire.
the second is a green plug that comes out of the wiring harness with the fuel injector plugs and the plug thats going to the ignition module. it looked to be two solid beige wires.
thanks alot.
Lance
thanks alot.
Lance
