Just wanted to document my hydro - boost install pictures as well as a few pieces of information that some may find useful when doing there own.
10mm socket needed to bleed front brakes
5/16" deep socket with 1/4" drive
when bleeding the rear you obviously can't use the socket to turn the bleeder with the hose connected. Hopefully the bleeder is clean enough to turn with the hose.
Front Bleeder is a 16mm 1.25 thread purchased from the help section. It does help to use PB blaster before loosening the bleeders if you haven't serviced them in sometime.
After reading throught he post, I kept seeing how quite a few people were having issues with brake pedal feel and return. All that is required is you take your time and follow the step.
1st maker sure your power steering pump is in good working order and the fluid is healthy.
Bench bleed your master cylinder - don't skip this step.
Bleed the each corner, with the bleeding of each corner my pedal feel became progressively firmer. Air in the system is compressible, fluid is not. If air is in the system the pedal will feel jacked up, bottom line.
Don't be lazy, the system works quite nice.
I switched from vacum to this due to my cam and the change in vacum I was seeing. Otherwise quite honestly a vacuum system is probably adequate for most.
I've included a couple shots of my install. I'm using an aftermarket steering pump so I was able to run braided stainless lines.
