How to rotate turbo down to align with intercooler
Heath
Elroyjr
I am trying to align turbo with intercooler. What screws do I loosen to turn the turbo down to the intercooler? (PT70p-trim)
Take the 6 13mm bolts on the backside of the compressor housing just loosen them.. then you can rotate the housting where you need it..
Be gentle!:biggrin:
These are on a stocker but these are the ones you have to loosen. They are on the back side of the compressor (cold side). JUST LOOSEN don't remove you may nick the fins on the impeller.Good Luck Jon Hanson
Email me if you have issues.
Sometimes, if you clock the turbo down too far the wastegate rod will bind if your running a internal gate.
Ive got alot of different setups, just email me and i will send pics if you need it.
BW:smile:
