P Paul Bellisario Member Joined Feb 25, 2013 Feb 20, 2015 #1 so under full boost I'm getting oil blow by. what have you guys used to fix this? vacuum pump?
E earlbrown runs with scissors Joined May 26, 2001 Feb 20, 2015 #2 Find the reason for the leakage and fix it. The easiest test is to pinch off the PCV line and see what that does. Never hurts to do a leak down test and see if the ring seal is tired.
H horndog Active Member Joined Feb 9, 2005 Mar 26, 2015 #5 Do a compression and leak down test. These tests will reveal alot.
