After the heads I think I will stop to prevent putting to much on the block. I'm putting in the Iron Cast Champion Heads how much do you think they will help?
TE44c Ball Bearing Turbo
Devils Own Alky Kit
Shift Recalibration Kit
3000 Stall Converter
Rebuilt Tranny
Eaton Posi Rear
60 LB Injectors
70MM Plenum
70MM Throttle Body
Cut Outs
LT1 Maf
Gen 2 Maf Trans
3 Inch Up Pipe
Turbo Tweak Alky chip
Rear Sway Bar
New Map Sensor
New TPS Sensor
3 inch Poston Down Pipe
Pypes Catback
Poston Headers Ceramic Coated
Dutweiler Neck Intercooler
Poly Urathane Body Bushings Kit
Rear Seat Brace Kit
Chrome Molly Fly Wheel
Frame Brace Kit
Hood Brace Kit
Front Connecting Brace Kit
High Performance Walbro Fuel Pump
Fuel Pump Wiring Upgrade
Remote Oiling System Upgrade
Underdrive Pulley set
High Rev Springs
Chrome Molly Push Rods
High Rev Lifters
Gn 110t Cam
Accufab Adjustable Fuel Regulator
Fuel Rail Feed Line
H&R Parts Poly Motor Mounts
H&R Parts Poly Trans Mount
Mickey Thompson Drags
New Gas Tank
Upgraded Ignition and Coil Pack
Weld Rims
Scan Master
Aftermarket Gauges All Around
Devils Own Alky Kit
Rebuilt Tranny
Eaton Posi Rear
60 LB Injectors
70MM Plenum
70MM Throttle Body
Cut Outs
LT1 Maf
Gen 2 Maf Trans
3 Inch Up Pipe
Rear Sway Bar
New Map Sensor
New TPS Sensor
Pypes Catback
Rear Seat Brace Kit
Frame Brace Kit
Hood Brace Kit
High Rev Springs
High Rev Lifters
Gn 110t Cam
Fuel Rail Feed Line
New Gas Tank
Weld Rims
Scan Master
