Everyone will call BS on me, but I can run 23lbs with 25 degrees timing on 89 Octane pump gas and alky, dial turned to about 8. Ive seen about .7 degrees of KR at the most. Ive cut the rolled lips off the up-pipe cause it seemed like a major source of turbulence. Turbulence= heat. I also bellmouthed my Dutt neck inlet, and the outlet. Deburred the TB inlet, and a whole bunch of little things, trying to keep things flowing smoothly and in turn keep heat down. It seems to be working. No power plate. Just a 1/2" plenum spacer. I keep it a bit on the rich side. 820-850mv O2's. Now to call BS on myself. This is in 1st and 2nd gear. I havent taken it to third cause I havent put my fuel pump in yet. The O2's dont drop, so the previous owner may have put a decent pump in there. But Im not going to push it and find out the hard way.
