84sithlord
- May 3, 2011
so i was thinking about going to hardware store and using 3" pvc pipe to make one out of. anybody done this? any better suggestions? thanks!
Once you see the little part that goes in the fender I think you'll be looking for one Jerryl. When I found it I realized it's just about perfect and no fender well cutting involved.This is for Charlie . . .
“If” you had intake air temps of 130 and sprayed alky . . . and temp dropped to 90, you should expect a 13-15 hp increase.
Well . . . post a pic.Once you see the little part that goes in the fender I think you'll be looking for one Jerryl. When I found it I realized it's just about perfect and no fender well cutting involved.
I will tomorrow Jerryl. I need to get the horns removed and see how well it works on the drivers side.Well . . . post a pic.
Cool!I will tomorrow Jerryl. I need to get the horns removed and see how well it works on the drivers side.
Well you asked for it Jerryl. Where the pipe fits is a 4" diameter and as you see I used a water pump so you get an idea of how large it really is. As to where I want to fit it in, here's an idea of what I'm thinking. That's where the horns were but to put it in I'll need to take the fender off, but I already planned to do this so it's not that big a deal. what I'm thinking is to build a box that the part (inlet) goes into and house the filter in it, then go from there to the carb.Well . . . post a pic.
I have the TR kit and it truly is no muss, no fuss. Worth every penny and then some. Installs seamlessly under the hood, and it looks great too! Dont get me wrong guys, i like to save a buck too but, some times its easier and best to go with the road thats been paved. James
84sithlord said:so i was thinking about going to hardware store and using 3" pvc pipe to make one out of. anybody done this? any better suggestions? thanks!
