G gnbeginer Member Joined Dec 23, 2011 Apr 27, 2014 #1 I bought a double pumper a lil while back and it included wiring but no instructions of how to hook it up. Could someone enlighten me on the best way to hook it up using a hobbs switch? TIA
T tta1240 CAMEL TOE Joined May 5, 2003 Apr 27, 2014 #3 Run power and ground to the switch then put a T in a vacuum hose and run to the switch Posted from the TurboBuick.Com mobile app
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Apr 27, 2014 #4 I assume you got relays w/ the pump harness. So, use the Hobbs power to trigger the relay for the 2nd pump.
G gnbeginer Member Joined Dec 23, 2011 Apr 27, 2014 #6 All I got with mine was a hacked together wire to run to back of car and a hobbs switch. I do have a relay that i can use if need be.
