Other way around.. bigger nozzles on alky.
Water uses very small nozzles.
To run alcohol whole system has to be alcohol compatible which means water is ok. Altho to run water.. pump, hoses, nozzles, fittings, etc are not critical. So if you design, design around worst condition which is alcohol.
