I am considering installing a high volume oil pump conversion kit on the stock front cover of my '87 GN. The kit basically consists of a 1/4" spacer plate and longer gears. The kit's instructions advise removing the front cover for the installation. I believe removing the front cover is for access to drill holes for two pins which positively locate the spacer plate. I would like to install this kit without removing my front cover. I think I can locate the spacer plate appropriately without drilling for the locating pins. Has anyone done a similar installation without removing their front cover? Am I in for any surprises or is this a fairly straight forward install? Thanks for relating your experiences.
