I did a bunch of research on this a while ago, and this is what I found.
Robert Shaw makes a high flow stat ( Robert Shaw/ Mr Gasket 330-160 thermostat) It can be cut down to fit the 86/87 motor.
Bad news. It may not work very well.
I spent this afternoon playing around, and ground down the lip on a old RS 330-180 stat to 1 3/4", to fit inside the manifold. It fits really well.
Here is the problem:
The body diameter (part that moves) of the stat is 1 9/16".
The ID of the inner step of the manifold bore is 1 11/16". The wall thickness of the manifold casting where the stat seats is 1/4".
The stroke of the stat is 3/8"
So since there is only 1/16 clearance between the stat body (part that moves) and the housing bore, not a lot of flow will happen untill the stat is almost fully open. And 1/4" of the initial opening is restricted. So that leaves 1/8" of unrestricted flow when the stat is fully open, kinda defeats the purpose.
Next was the Stant SuperStat. It seems to be the route to go. Sorry I don't knoiw the part #.
Or another option is to go to an auto parts supplier and look at all the 160 deg stats and see which one has the biggest internal bore and stroke that will fit in our housing. As far as outside diameter...a little creative use of tin snips and a file/grinder will make it fit perfectly.
I hope this helps.
I'm curious about your conversion to the NPG+... Is just changing to a high flow stat all that is required to use the Propylene Glycol, of is this the complicated setup with the vapour condensation tank etc.?
Paul
