- Feb 18, 2006
Throwing a ce light? What the code?
Exhaust leaks hurt definitely pre turbo leaks. Get it welded up soon you'll notice a big difference. The o2 sensor detects more oxygen in your exhaust and it's telling the ecu to add fuel= rich condition.Anyone? Anyone? Bueller?
What's you o2mv reading and the a/f numbers?
Thanks man! I haven't yet. I have one from AutoZone to put on (Cardone), but haven't yet.
I'm not trying to stir up some crap, but are your referring to this one on Full Throttle, or another type?Are you reading fuel pressure with a liquid filled rail mounted gauge? Those things will give erratic readings depending on temp. Radiant heat from the engine will lower reading. May explain why fp rises when left to sit with engine off.
Fuel would have to saturate the evap canister to make the tune rich. In that case you would smell raw fuel.
At this point I would say the chip or the mass air flow is the culprit. A high maf signal will make the tune rich.
I would be looking into a lt1 maf with a translator and a new chip but not before verifying the maf signal is running high.
Did you get the scanmaster hooked up yet? Take note of AF reading at idle and post back.
Rick
http://www.fullthrottlespeed.com/tu...or/rail-mount-fuel-pressure-gauge-for-gm.html
