I have searched every where and cannot seem to find any info on the problem i am having with my passenger side door lock. The power door lock does not unlock the door. When you hit the power lock switch to unlock the door, the actuator moves the linkage, but not enough to disengage the lock. After you hit the switch to unlock the door, you have to pull up on the door lock (the piece that sticks up thru the top of the door) an additional
1/8th of an inch to disengage the lock.
Is there some type of adjustment that can be done to correct this?
I don't think the actuator is bad, I watched it operate as I operated the switch. The linkage seems like it needs adjusting, but I don't see where I can.
Thanks In Advance
Thanks In Advance
