OK had a little time off today to work on my t type today.car started running lean a couple days ago pump was dieing.I have a new F2000169 walbro new but hadn't installed.Car was supposed to have a new pump when I bought the car.So I drop the tank pull out the sender unit it has a stock pump no big deal.I get my new pump out no manual oh well should be pretty straight forward.well it had the wrong style connector on the sender but only 2 wires how hard can that be cut one at a time solder on new terminal connectors.The car was a hot wire kit down to the connector before the tank put all back together and the pump run no fuel pressure well I figured pump must wire different switched the two wires at the connector and pump fired right up car runs great .now the problem no fuel gauge I guess there is 2 different ways the connector could have been wired mine are tan pink black does anyone have or know where I can look at the manual 14-17 some kind of mod i have to do with a paper clip (really) to make the fuel gauge work correctly sorry for the long post I've been searching 2 hours on here cannot fine the mod and I'd like to only drop the tank one more time TIA.
Bill
Bill
