8 86TType Slick 86 T-type Joined May 8, 2004 Oct 12, 2011 #1 At idle my scanmaster read.. 02-360-500 AF-05 L8-29-31 INT-128 BL-128 ATS-72 TPS-.28 IAC-00 CC-37-248 ANY SUGGESTIONS
R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Oct 12, 2011 #2 TPS is suppossed to be .38-.46 IAC is suppossed to be anything above "zero" So close throttle blade by turning adjuster screw. 1/2 a turn at a time until you get numbers on IAC. Then readjust TPS. You may have a vacuum leak thats why the 0 IAC.
D DOUGGN Member Joined May 17, 2011 Oct 12, 2011 #4 Driver side of throttle body. The screw may be covered by a small rubber cap.
N NorEaster Member Joined Jun 4, 2010 Oct 13, 2011 #5 DOUGGN said: Driver side of throttle body. The screw may be covered by a small rubber cap. Click to expand... Careful, they can break.
