WHen I turn on my lights (head lights) I lose my dash lights, rpm led cluster back ground even the ones around the radio & gear indicated plz help me this sucks
You have a short. It is probably the wire for the bulb of the indicator light under your console. This wire almost always is the culprit. The constant shifting breaks the wire and shorts to the metal bracket of the shifter. Remove the console and fix the wire and replace the blown fuse and you will be good to go.
