Sweetwater GN
Unstoppable :)
- Jun 1, 2010
Can't get the compressor on, clutch engages with 12v and ground hooked to it. 12v coming down the green wire from the relay and lo press cut off, so I know that is working. If I ground the black wire off the clutch the comp runs, but when I hook it back in line to the switch on the back of the comp. it won't run. So I guess that means the hi press. switch is breaking the ground ? How I can test this ? System had a bit of a leak till I sealed it... no air got in and so I don't think my pressure is too high either. What do I test and please be specific wire wise etc, not familiar with AC besides the crash course I'm getting here trying to get it running.
