getdowngranny
Mr. Fix It
- Jan 8, 2006
I am going to order some new rear wheels to put a set of Nitto 275/60/15 drag radials. The wheels will be Weld Racing RT-S. I want to try to tuck the tire in the wheel well a bit and need to figure out what size to order. My question is, will a 15x8 wheel have less tire bulge with said tires than a 15x10? Also since I want to try to tuck it in a bit, will a 5.5 Backspacing work? I have the fender rolled but no frame notch. The only options on the RTS for our setup is 4.5 or 5.5 Backspacing. I think a 15x8 with 4.5 Backspacing and appropriate spacers (if needed) will work. I do not want to notch the frame. Let me know what you guys think or if I should try a different combination. Thanks in advance.
