All right guys, help me out with the stock headlight wiring colors.
Low Beams:
Low = Tan (x2 on drivers side)
High = Green (x2 on pass side)
Ground = Black
High Beams:
High = Green
Ground = Black
Am I missing something, or incorrect here? I am installing H4 LED bulbs that are supposed to be PnP after swapping the low beam ground/low wires on the stock plug, but things arent lining up/working correctly. My new highs will work with switch flipped, but the lows hooked up per below will only dimmly light up. I actually had the drivers side tested and working lows, moved to the pass, then both only dim light the lows now.
H4 wiring looking into stock connector:
gnd | _ | high
low
Thoughts:
1. Weak switch decide to give up
2. Stop messing with it and buy the casper harness
3. Bad ground (checked both grounds)
4. Low voltage wont light LED's (tested and lows see 11.8v with engine off lights on)
Perplexed.... over something so simple. Need a night cruise in my life, help me get it back on the road!!!!
Low Beams:
Ground = Black
High Beams:
High = Green
Ground = Black
gnd | _ | high
low
Thoughts:
