nailheadpowered
- Oct 31, 2004
just recieved a set of headers from known manufacturer and the passenger side header is off a little, when you bolt it up the first bolts are fine on the first cyl. the second set are a little tight but go in the third cyl i got the bottom in somewhat but the top one does not line up evenly and when i called the company they instructed me to open the holes up a little to allow alignment, also the header is up against my upper A-Arm though i have 5 shims in the rear A-Arm bolt that has it pushed out a bit but still the header is right up against the A-arm, and they stated to grind my A-arm to make room. my question is should i keep this header and do as they say or send it back for a replacement? funny thing is i am replacing a set of postons that fit perfect LOL.
