Q quadzila Member Joined Mar 22, 2010 Jul 20, 2014 #1 I had these for about a year. 170.00 Lower rear control arms, 78-87 GM G-body +1/4" CUSTOM LENGTH (adds 1.5 degrees pinion) Attachments axles posi gears 004.jpg 1.3 MB · Views: 58
T TurboBuick86 Active Member Joined Sep 24, 2008 Jul 20, 2014 #2 P/M u Posted from the TurboBuick.Com mobile app
T Turbo6Smackdown Well-Known Member Joined Dec 31, 2005 Jul 29, 2014 #6 What does 1.5 more degrees of pinion angle do?
B bad V6 Member Joined Oct 9, 2005 Jul 30, 2014 #8 Properly adjusting the geometry of the rear suspension will allow the tires better traction.
T Turbo6Smackdown Well-Known Member Joined Dec 31, 2005 Jul 30, 2014 #9 Got that part. I was asking specifically about that 1.5 degrees of pinion angle. Will that help every car with a factory setup? Is there a down side to that? Why isn't every trailing arm a quarter inch longer?
